Get warning "The Min and Max values for the "in" signal are out of bounds in regard to this "to" signal" when generating Xbuilder project
  • Get warning "The Min and Max values for the "in" signal are out of bounds in regard to this "to" signal" when generating Xbui...
  • sesa150555
    sesa150555
‎2018-09-07 02:02 PM
Get warning (error) "The Min and Max values for the "in" signal are out of bounds in regard to this "to" signal" when generating Xbuilder project
TAC Xbuilder
This warning refers to min and max values of signals in a connection object not matching.
This is just a warning that there is a possibility that the receiver can't handle some of the values that can be sent.
No action is required.
Tags (3)
  • 4854
  • maximum
  • minimum
