Get "Type error: cannot call method "toFixed" of null" error message when opening a TGML graphic, upgraded to Vista 5.1.7
  • Get "Type error: cannot call method "toFixed" of null" error message when opening a TGML graphic, upgraded to Vista 5.1.7
  • sesa177673
    sesa177673
‎2018-09-06 12:55 PM
A TGML script has stopped working after upgrading to Vista 5.1.7
TAC Vista Workstation 5.1.7
TGML editor 5.1.7 219
Javascript method toFixed can only be used with numerical values. The TGML engine in TGML 5.1.7 is stricter than the older versions, so an upgraded script may have worked in previous versions.
An example when using convertCustom element.
Original script:
function convert(value)
value = value.toFixed(2);
return value;
should be:
value = Number(value).toFixed(2);
return value;
  • 6990
