Get "Not enough storage is available to complete this operation", could not connect to Vista message in workstation.
  • Get "Not enough storage is available to complete this operation", could not connect to Vista message in workstation.
  • sesa177673
    sesa177673
‎2018-09-10 06:55 AM
Get "Not enough storage is available to complete this operation", could not connect to Vista message in workstation. The message appears periodically in Workstation without any operator input.
Vista 5.1.X
Workstation 5.1.X
There are at least 2 possible causes for this.
1. Over utilisation of the PC's resources - in other words there is not enough physical memory on the PC.
2. Incorrect DCOM settings.
Check the memory usage in the Task Manager. Is there RAM memory available when Vista is idling (not running reports and retrieving logs)? If the physical memory is used up then the only solution is to increase the memory on the PC/server.
Alternatively, if there is memory available, check the DCOM settings for Vista. These can be found in the TAC Vista installation manual
  • 7242
