Get message "Could not open or create file.: AC_Xenta_721.cfg" in the Xenta Server error log and in TAC vista event log.
  • Get message "Could not open or create file.: AC_Xenta_721.cfg" in the Xenta Server error log and in TAC vista event log.
  • sesa150555
    sesa150555
‎2018-09-06 02:24 PM
Get message "Could not open or create file.: AC_Xenta_721.cfg" in the Xenta Server error log and in TAC vista event log. The message appears about every 10 seconds.
  • Xenta Server
  • Xenta 511, 527, 701, 711, 721, 731
This is a defect in the software.
This happens if you use the internal online signal e.g. as the input for an alarm.
Take out the references to the internal online signal
Labels (3)
  • Satchwell MicroNet
  • TAC INET
  • 4050
