Get-VM is not recognized error when installing PCT 2
Select a Country
  • Get-VM is not recognized error when installing PCT 2
  • CraigEl
    CraigEl
CraigEl Champion
‎2024-02-14 08:30 PM
on ‎2024-02-14 08:30 PM
When installing PCT 2 the following error is seen:
Error: System.Management.Automation.CommandNotFoundException: The term 'Get-VM' is not recognized as a name of a cmdlet, function,script file, or executable program.
Project Configuration Tool 2.0
The Hyper-V Module for Windows PowerShell is not installed.
Follow these steps in Windows 10 to install the Hyper-V Module for Windows PowerShell:
  1. Right-click on the Start button and click Programs and Features.
  2. In the Programs and Features dialog, click Turn Windows features on or off
  3. In the Windows Features dialog, check the box for Hyper-V Module for Windows PowerShell and click OK.
  4. The dialog will signal completion and the module will be installed.
Labels (2)
  • Project Configuration Tool
  • CraigEllis24
0% helpful (0/5)
