Get Error message "Error: Unable to create blueprint file" when trying to download to Xenta device
  • Get Error message "Error: Unable to create blueprint file" when trying to download to Xenta device
  • sesa150555
    sesa150555
‎2018-09-10 12:11 AM
  • Xenta 301
  • Xenta 302
  • Xenta 281
  • Xenta 282
  • Xenta 283
  • Xenta 401
This can be caused if one or more of the I/O modules from the device does not have any subnet/node address defined.
  1. Click on the Xenta in Workstation
  2. In the pane to the right double click on $IO
  3. Right click and select properties on the I/O modules
  4. Make sure that all modules have subnet node defined.
  • 5638
