Function Blocks as object controller with StruxureWare Building Operation
  • Function Blocks as object controller with StruxureWare Building Operation
  • sesa139513
    sesa139513
‎2018-09-06 01:08 PM
StruxureWare Building Operation FB Program at site
When commissioning the local node with a LNS tools (NL220), one cannot see the functional blocks as object controller in the LNS tool, but rather have all the SNVT in the static node. Is it normal? The problem is, if one has a lot of SNVT, it is not clear.
Functional blocks created do not have a functional block index to be able to present them correctly. All Functional blocks have same index causing the presentation issue mentioned above.
  • 6472
