Forta series actuators with IP65
  • Forta series actuators with IP65
  • SESA150559
    SESA150559
‎2018-09-06 10:28 AM
Is it possible to order a Forta actuator with IP class 65?
M400
M800
M1500
M3000
Some environments are requiring a higher than normal IP rating.
Unfortunately the design of the Forta actuators are only IP classed to IP54. No IP65 version is available.
An additional weatherproof bag may be added to cover the actuator. However, such bags needs to be purchased from other sources as they are not part of our portfolio.
  • Field Devices
  • 13043
