Forta series actuator for V321 DN125-DN150
  • Forta series actuator for V321 DN125-DN150
  • SESA150559
    SESA150559
‎2018-09-06 11:12 AM
Which adaptor should be used when mounting a M3000 actuator on a V321 DN125/150?
V321
Forta
M3000
M22
M50
Forta actuators are a direct fit to V321 on all sizes DN100 and smaller unless stated differently in the catalogues/data sheets.
The M3000 actuator will not fit on the V321 DN125 and DN150 sized valves due to the different design of the valve body. For DN125/150, actuators M22 and M50 should be used.
  • Field Devices
  • 10916
