Forta actuator on valve V395
  • Forta actuator on valve V395
  • SESA150559
    SESA150559
‎2018-09-06 12:25 PM
Is it possible to use the current Forta series actuator on the old V395 valve?
V395:
7319501000
7319505000
7319509000
7319513000
7319515000
7319519000
TAC Forta
Forta application suitability.
The Forta series actuators are suitable for use on the V395 valve. The data sheet for V395 has the M800 listed as recommended actuator.
  • Field Devices
  • 7801
