For a high temperature application, how can a TS-8204 be programmed to read accurately when connected to a MNL controller?
  • For a high temperature application, how can a TS-8204 be programmed to read accurately when connected to a MNL controller?
  • sesa119747
    sesa119747
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 02:51 PM
TS-8204
Require instruction on configuring the TS-8204 temperature sensor for accurate reading.
Connect the TS-8204 sensor and install a 2.49 kohm resistor in parallel (1% resistor or better).
Set the Analog Input object to Balco and link the output to a Curve Fit object.
Curve Fit objects are supported only on controllers with Rev.3. They are not supported on VAV controllers.
Configure the Curve Fit X and Y data points as follows:
  • Data Point X1 10.8
  • Data Point X2 34.5
  • Data Point X3 57.0
  • Data Point X4 78.0
  • Data Point X5 97.8
  • Data Point X6 116.4
  • Data Point Y1 200
  • Data Point Y2 240
  • Data Point Y3 280
  • Data Point Y4 320
  • Data Point Y5 360
  • Data Point Y6 400
  • TAC IA Series
  • 2917
