File equalization is not available on the workstation if the link type is NetPlus Router, Integrated Dial, or Integrated NPR dial.
  • File equalization is not available on the workstation if the link type is NetPlus Router, Integrated Dial, or Integrated NPR ...
‎2018-09-06 10:41 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:42 AM
Although site operation appears normal, there are problems with file equalization when the desktop PC is direct connected to the NPR. Active Configuration Profile, Link type is NetPlus Router.
  • I/NET Seven
  • NetPlus Router
  • Integrated Dial
  • Integrated NPR dial
File equalization is not available on the workstation if your link type is NetPlus Router, Integrated Dial, or Integrated NPR dial.
File equalization is not available on the workstation if your link type is NetPlus Router, Integrated Dial, or Integrated NPR dial. Refer to TCON 298, 3-13 for more information.
  • TAC INET
  • 1220
