Fiber Optic Interfaces (FOI) in I/NET 2000
  • Fiber Optic Interfaces (FOI) in I/NET 2000
‎2018-09-06 03:37 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:42 AM
What are the dip switch settings for each Fiber Optic Interface (FOI) in I/NET 2000 Controller LAN and subLAN?
Can FOI communications be alarmed? How do you test them?
Does the FOI need to be addressed in I/NET?
  • I/NET 2000
Configure the network to work on FOI.
Controller LAN Settings:
SubLAN Settings:
  • 1 = Off
  • 2 = Off
  • 3 = On
  • 4 = Off
  • 5 = Off (If no CRR)
  • 6 = Off
  • 7 = Off
  • 8 = On
  • 9 = Off
  • 10 = On
  • 11 = On
  • 12 = On
  • 1 = Off
  • 2 = Off
  • 3 = On
  • 4 = Off
  • 6 = Off
  • 7 = Off
  • 8 = On
  • 9 = On (9600 subLAN speed)
  • 10 = On
  • 11 = On
  • 12 = On
Notes:
  1. When testing the fiber optic section of the network, tests can be done in "Single-Mode" or "Multi-Mode." All testing must be performed in "Multi-Mode."
  2. Fault alarms can be sent from the FOI to a remote location using fiber line faults. You need to have Counter Rotating Rings (CRR) to get this feature.
  3. FOIs are not addressable. The FOI is transparent or invisible when viewed through a workstation or viewcon screen of the 7728 or 7798.
Refer to TCON087, Fiber Optic Interface for more details.
  • TAC INET
  • 1069
