Feature License Propagation Issue using Engineering License ("New system")
  • Feature License Propagation Issue using Engineering License ("New system")
  • PeterEdvik
    PeterEdvik
  • Katha
    Katha
Lt. Commander Katha Lt. Commander
‎2025-10-24 04:23 AM
Last Updated: Janeway PeterEdvik Janeway ‎2025-10-24 04:25 AM
When an Engineering License ("New system") is created and activated on an Enterprise Server (ES) that has been upgraded from EBO 6 or earlier to EBO 7.0.3, the feature licenses do not propagate to Automation Servers (AS) that are still running EBO 6.0 or earlier
EcoStruxture Building Operation
  • Software Companion
  • Device Administrator
  • Centralized Licensing
The current Engineering License offering with the "New system" does not support scenarios where the top-level server has been upgraded from EBO 6 or earlier to EBO 7.0.3.
In such cases, the license propagation mechanism may not function correctly.
To ensure proper license propagation:
  • Recommended Setup:
    Create and activate the Engineering License ("New system") on a top-level server with a clean EBO 7.0.3 database. In this configuration, feature licenses will be inherited correctly by AS units running EBO 7.0 and earlier.
  • Alternative Workaround:
    If the ES has been upgraded from EBO 6 or earlier to EBO 7.0.3 and AS units cannot be upgraded immediately ( Multi-system) :
    • Consider manually assigning feature licenses ( Demo lic)  to the AS units.
    • Or, migrate AS units to EBO 7.0 or later to restore automatic license propagation.
  • KatharineVasquez25
