Failure when processing USB connection event error when adding a new Automation Server to Device Administrator
  • Failure when processing USB connection event error when adding a new Automation Server to Device Administrator
  • CraigEl
    CraigEl
Administrator CraigEl Administrator
‎2023-10-09 08:17 PM
on ‎2023-10-09 08:17 PM
A new Automation Server won't load in Device Administrator versions earlier than EBO 2022. A "Failed to process USB connection event for DevicePath:\\?" error is shown when adding the device.
  • Building Operation Automation Server AS-P with Secure Boot
  • Building Operation Automation Server AS-B Scalable
Secure Boot/Scalable Automation Server hardware is not supported in EBO versions prior to EBO 2022.
It is not possible to install EBO versions prior to EBO 2022 in Secure Boot/Scalable Automation Server hardware. Verify the Automation Server part number to ensure it is a non-scalable/non-secure boot version. Refer to the Part Number and Hardware and Software Matrix for a list of parts numbers and their associated EBO version compatibility.
Tags (2)
  • CraigEllis23
  • RobertAndriolo24
100% helpful (3/3)
