Failed to call pILiveData error when editing Schedule object in Continuum 1.94
  • Failed to call pILiveData error when editing Schedule object in Continuum 1.94
‎2018-09-11 07:25 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:42 AM
After upgrading to Continuum 1.94, Cyberstation throws the following error:
Failed to call pILiveData -> GetLiveData().  ACDataServices has an error.
Andover Continuum
  • Continuum 1.94
  • Schedule
  • Error
This behaviour is due to a bug that was described in TPA-BOST-12-0002 00 Schedule Exception Errors.
Install the CyberStation v1.94 SP1 - Software which can be found on the Exchange Extranet.
  • 11798
