External resistors required for Biasing and Terminating RS-485 trunks connected to an Automation Server
  • External resistors required for Biasing and Terminating RS-485 trunks connected to an Automation Server
‎2018-09-11 03:49 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 03:59 AM
External resistors are required for Biasing and Terminating RS-485 trunks connected to an Automation Server (AS)
  • SmartStruxure Automation Server (AS) with  RS-485 trunk(s) under it.
  • Field controllers on the RS-485 trunk; for example, the Network 8000 ASD controllers (MZ2, PEM1, etc)
Bias and terminating resistors are not built into the AS hardware.
External resistors are required for Biasing and Terminating RS-485 trunks connected to an  Automation Server (AS).
See the Technical Reference Guide, revision 1.3, pages 2723, 2724, and 2771.
Also check out the SmartStruxure-RS485-Network Installation Quick-Help video on the Exchange.
Biasing and Termination details are now found in the "RS-485 Communications" chapter of SpaceLogic - Hardware Reference Guide
Tags (6)
  • 13106
  • DavidShore23
  • end-of-line
  • pull-down
  • pull-up
  • termination
