External log storage with TimescaleDB backward compatibility
  • External log storage with TimescaleDB backward compatibility
  • Mahmoud_Sayed
    Mahmoud_Sayed
Kirk Mahmoud_Sayed Kirk
‎2023-05-30 07:46 PM
In a multi-version system, will the database schema in the PostgreSQL database be compatible with EBO servers with lower versions?
  • Building Operation Enterprise Central
  • Building Operation Automation Server
  • Building Operation Automation Server Premium
  • Building Operation Automation Server Bundled
  • Building Operation Edge Server - Standard
  • Building Operation Timescale Database
In a multi-version system the database schema in the PostgreSQL database needs be compatible with all servers in the system.
  1. The DB schema is backward compatible. The same schema can be used for the complete system and it can be upgraded to the latest version compatible with the top-level server.
  2. Compression is done on the PostrgreSQL/TimescaleDB side and since it’s not configured in EBO, the compression will work for EBO servers with lower versions. Compression needs at least schema version 9 for EBO2023 or schema version 13 for EBO2024 and TimescaleDB version 2.0 or higher, refer to: Compression for TimescaleDB
Tags (2)
  • MahmoudSayed23
  • MahmoudSayed24
