Extended Logs not showing up in the Reports Server
  • Extended Logs not showing up in the Reports Server
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 10:42 AM
Database table tbLoggedEntities does not contain trend data.
Report Server
Extended Trend logs must reside on the ES and must have the "Include in Reports" parameter set to "True"
  • Ensure the Extended Trend Log resides in the ES. If it is in an AS, you can create another Extended Trend Log in the ES with that as the reference.
  • Ensure that all Extended Trend Logs that you wish to see in Reports have the parameter "Include in Reports" set to "True"
  • 12337
