Explaining a Gateway
  • Explaining a Gateway
  • sesa139513
    sesa139513
‎2018-09-06 03:20 PM
What is Gateway?
I/NET Site
What is Gateway?
A gateway is a method of enabling communications between two or more network segments. A gateway is usually a dedicated computer that runs gateway software and provides translation service, which allows for communications between dissimilar systems on the network.
For example, using a gateway, an Intel-based PC on one segment can both communicate and share resources with a Macintosh computer or mainframe. Another function of gateways is to translate protocols. A gateway can receive an IPX/SPX message that are bound for a client running another protocol, such as TCP/IP, on a remote network segment. After the gateway determines the message packet's destination is a TCP/IP station, the gateway will actually convert the message data to the TCP/IP protocol.
  • TAC INET
  • 1388
