Explaining Conversion Coefficients
  • Explaining Conversion Coefficients
  • sesa139513
    sesa139513
‎2018-09-06 03:16 PM
What are Conversion Coefficients?
I/NET site
These are mathematical constants a controller uses to convert analog input / outputs from the digital value used by the microprocessor to analog display values. Conversion coefficients are also used to convert digital commands from the microprocessor into analog outputs which are then used by field interface devices.
  • TAC INET
  • 1557
