Every MicroFlo II is designed for only one Room Temperature Sensor
  • Every MicroFlo II is designed for only one Room Temperature Sensor
  • sesa119747
    sesa119747
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-11 01:25 AM
Can more than one Room Temperature Sensor be connected to a MicroFlo II?
TAC IA Series
  • Network 8000
  • Microflo
Site changes / retrofit
The only supported configuration is one Room Temperature Sensor for up to four MicroFlo II controllers (see below).
TAC Hardware Installation Practices
TS-90250-850
Communication/Sensor wiring for up to 4 TAC Microflo lls sharing a single Room Temperature Sensor.
Room sensor includes a 11K ohm resistor and setpoint with ASD communications. Do not add another 11K ohm resistor when installing.
  • The ASD communication wiring MUST be isolated from the sensor/setpoint wiring. Use separate shielded cables for each.
  • Connect the SHIELD DRAIN wire to the SHLD or GND terminal at the controller.
  • If a ground is available at the room sensor, connect the DRAIN wire to ground. If a ground is not available, tape the DRAIN wire back at the external device only.
  • A 120 ohms resistor (part number 40-1758) must be installed across the ASD terminals at each end-of-line (EOL).
  • Total overall wire length between TAC MICROFLO lls and the room sensor MUST not exceed maximum distance specified.
  • Set each address switch to uniquely identify each TAC MICROFLO II controller (refer to the job drawings).
  • Set the MASTER/SLAVE jumper pins to the correct position (factory shipped as MASTER units).
I/O Wiring - TAC MICROFLO
  • TAC IA Series
  • 12987
