Error when opening OpenLNS Plugin in SmartStruxure
  • Error when opening OpenLNS Plugin in SmartStruxure
  • sesa145087_brid
    sesa145087_brid
‎2018-09-11 09:46 AM
When open the OpenLNS Plugin in SmartStruxure, an error will pop up: The procedure entry point ?OnFinalRelease@xRefCountObject@@MBEXXZ could not be located in the dynamic link library LdvxShared.dll.
SmartStruxure
OpenLNS
LonMaker 3.1
Windows 7
LonMaker 3.1 is not supported in Windows 7, even though sometimes it will work. But when it works with OpenLNS plugin, it will fail.
1. Upgrade LonMaker from version 3.1 to 3.2. Or remove LonMaker and other Echelon program in the computer. Also uninstall the OpenLNS program.
2. Try to install the OpenLNS program again. It should work now.
  • 16523
