Error when Modifying a door in I/NET: Any changes made to the door extension will be stored in the SLI
  • Error when Modifying a door in I/NET: Any changes made to the door extension will be stored in the SLI
‎2018-09-06 03:27 PM
I tried to modify a door point and I/NET gives me the following dialog box explaining that any changes to the door extension will be stored in the SLI. What would cause this dialog box to occur?
I/NET
If the communication between the SLI and the DPU is currently unavailable, this will cause the dialog box to occur. Please note that once the communications between the SLI and the DPU have been re-established the stored changes will be sent to the DPU.
  1. Select Edit MCU configuration to verify communication failure
  2. Not any Red text, as these addresses are offline
  3. Troubleshoot and repair physical communications
  • TAC INET
  • 1035
