Error: "There is no folder for this object" when creating an object in Workstation
  • Error: "There is no folder for this object" when creating an object in Workstation
  • sesa150555
    sesa150555
‎2018-09-06 03:08 PM
I get an Error message saying, "There is no folder for this object" when I try to create an object.
Vista Workstation
This error occurs if there is a dash or hyphen (–) in the name of the object being created. Vista uses the dash to define folder paths in the database, e.g. a graphic named RTU-1. Vista sees this as a graphic "1" in the folder "RTU."
Do not use dashes or hyphens in the naming convention for Vista objects. Either eliminate it altogether, or use underscores (_) instead.
  • 1863
