Error: "Runtime Error 429.Active X Component Can't Create Object" While Running Exporter Reporter in I/NET 2000
  • Error: "Runtime Error 429.Active X Component Can't Create Object" While Running Exporter Reporter in I/NET 2000
‎2018-09-06 03:27 PM
I/NET 2000
OBDC Install Setup program has not been run.
Run the ODBC Install setup program from the I/NET installation CD. \ODBCInstall\disk1\setup.exe.
  • TAC INET
  • 1056
