Error "BC client Path from registry" affecting Alarmview
  • Error "BC client Path from registry" affecting Alarmview
  • sesa150561
    sesa150561
‎2018-09-06 09:51 AM
When logging in, user sees error: "BC client Path from registry"
If the error is acknowledged, everything works except for the Alarmview.
TAC Vista
Vista
If a created user does not have access to the Alarmview when logging in, the error appears.
Give the user access to view the Alarmview:
  1. Go to $Alarmview
  2. Right click on $Alarmview and choose "Authority"
  3. Give the user/group that has the problem at least read rights
  • 15041
