Error message trying to save changes in Menta Editor
  • Error message trying to save changes in Menta Editor
  • RobertAndriolo
    RobertAndriolo
  • PeterEdvik
    PeterEdvik
Janeway PeterEdvik Janeway
‎2019-09-22 08:55 PM
Last Updated: Administrator DavidFisher Administrator ‎2019-11-08 01:01 PM
An error message is displayed when trying to save changes to a Programmable Xenta in Menta Editor. The error message is:
Tam32
Save Error
Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
(E)
Error message trying to save changes in Menta EditorError message trying to save changes in Menta Editor
  • Building Operation Workstation 3.0.2 or earlier
  • Xenta 281
  • Xenta 301
  • Xenta 401
A defect in Menta Editor causes this error to be displayed when a SNVT name in the Menta application is identical to the programmable Xenta device name.  An example of this is shown below:
This problem has been fixed in Hotfix 3.0.2.2500 and the fix is included in version 3.1. For earlier versions there are two ways to resolve this problem; Either a) rename the Xenta device, or b) rename the SNVT.
a) Renaming the Xenta device
  1. In Workstation right click the Xenta device and choose Rename
  2. Click OK
  3. Now you can edit the Xenta in Menta Editor without getting the error message
b) Renaming the SNVT
  1. Right click the Xenta device and choose Edit
  2. In Menta Editor double click the block with the SNVT binding to edit the block
  3. Click the Bind... button to edit the binding
  4. Change the name, click OK to close the dialogs and Save the changes
Tags (2)
  • PeterEdvik19
  • QC 41861
