Error message: "Failed to run DcuXml.exe" when importing I/NET .sav files into XBuilder
  • Error message: "Failed to run DcuXml.exe" when importing I/NET .sav files into XBuilder
  • Anonymous user
‎2018-09-07 01:45 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-10-28 11:17 AM
TAC INET, TAC Vista
XBuilder 1.6.0
When XBuilder imports I/NET save files, it does a simple batch of all of the save files for the import process. It creates a path for the import into XBuilder. A typical path might look like this:
C:\TAC XBuilder Projects\MyProjectName\Files\INET\dcu0102,dcu0103,dcu0104
This example shows the import of 3 I/NET save files with a character length of 72 for the batch process. This process is limited to 2048 characters. Importing 15-20 save files will cause a crash.
To squeeze a few more save files into XBuilder, shrink that path as much as possible. For example:
  1. Rename the default "TAC XBuilder Projects" folder to something shorter.
  2. Rename the project to something shorter.
  3. Move .sav files to another location, even temporarily to the C:\ drive root to eliminate extra path data.
Example:  C:\XBPrj\MyPrj\Files\INET\dcu0102.sav.  This path shrinks the directory at the front end to allow for more save files on the backend.
Labels (2)
  • TAC INET
  • 3112
