Error message, "Error moving image files" when uploading controllers in WorkPlace Tech 4.0
  • Error message, "Error moving image files" when uploading controllers in WorkPlace Tech 4.0
‎2018-09-11 12:29 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 03:58 AM
When using WPT 4.0 to upload controller databases, the system may display the following error message at the end of the upload process:
WorkPlace Tech version 4.0
This error will occur whenever an Upload is performed under the following circumstances:
1. Any time the WPT project path is changed from the factory default such that it references a  drive path other than "C:", and the project is opened from that location.
2. Any time a project is opened through the use of the "Browse" function, and that project is located on a drive other than "C:"
See the attached Technical Alert TA04-05 for complete details.
  • TAC IA Series
Tags (2)
  • 12357
  • mnl
100% helpful (1/1)
