Getting error inserting a row in the database when refreshing a personnel template.
Andover Continuum
CyberStation
Warning
AreaLink table contains NULL instead of zero in the ClearanceLevel column.
WARNING: Unless knowing exactly what you are doing, deleting entries from your database can cause irreversible harm to your database and can potential cause corruption. Make sure to perform a full SQL Database backup before attempting to make any changes to the database. (See Move / Backup / Restore a database on a Single User SQL2005 Express system for details on how to backup your database and if not already installed, where to get Management Studio from)
Run the following query:
Update AreaLink Set ClearanceLevel = 0 where ClearanceLevel is null
