Error generating Workplace Tech Flow Balance report in HTML format: "Unable to create a report in HTML format"
  • Error generating Workplace Tech Flow Balance report in HTML format: "Unable to create a report in HTML format"
‎2018-09-09 11:51 PM
Using the WPTech Flow Balance software and trying to generate the balance report in HTML format.  When doing this receive  the following warning:
MicroNet BACnet Flow Balance Software
WorkPlace Flow Balance Tool
MNB-V2
Cause has not been determined.
If this “Warning” appears check “My Report” folder”, the HTML may have been created even though the “Warning” was issue. The cause of this anomaly has not been determined at this time.
This article will be updated when a solution is found.
  • TAC IA Series
  • 5518
