Error adding a LON application to a project in WorkPlace Tech 5.x from the pre-engineered "WPT Applications" zip file: AppXMLAddon Error Code: -2032465751 Code meaning:...
  • Error adding a LON application to a project in WorkPlace Tech 5.x from the pre-engineered "WPT Applications" zip file: AppXML...
  • sesa116877
    sesa116877
‎2018-09-06 02:57 PM
The following error message appears when adding a LON application to a project in WorkPlace Tech 5.x from the pre-engineered "WPT Applications" zip file: AppXMLAddon Error Code: -2032465751 Code meaning: Unknown error 0x86DB08A9s.
  • WorkPlace Tech 5.x
  • WPT Applications.zip
Workplace Tech encountered one or more values in the application that contain invalid characters. Generally, the most common value that causes this issue is the nciLocation SNVT. The value that should be in this SNVT is "/0", but through a previous Microsoft Visio conversion, it was replaced with a "vertical bar" character.
  1. Locate the invalid characters
  2. Replace them with valid ones or delete them.
  3. Once this is done, select "Application - Rebuild Application" from the drop-down menu.
  • TAC IA Series
  • 2650
100% helpful (1/1)
