Error 'Operation was not performed' when trying to run a Graphic object.
  • Error 'Operation was not performed' when trying to run a Graphic object.
‎2018-09-06 10:47 AM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:39 AM
CyberStation
Warning
Corrupted Continuum installation
Uninstall Continuum
Delete Continuum folder  (make sure to save any needed files such as pin, menu etc)
Delete Continuum entries in the registry (Make sure to backup registry as a precaution)
HKEY_CURRENT_USER\Software\Andover Controls\Continuum
HKEY_LOCAL_MACHINE\SOFTWARE\Andover Controls\Continuum
Re-install Continuum
  • 12104
