Error 'Object does not exist' when trying to use is like with Device ID in a list view qualifier.
  • Error 'Object does not exist' when trying to use is like with Device ID in a list view qualifier.
  • AbeMeran
    AbeMeran
‎2018-09-11 07:35 AM
Has a ListView defined under a controller that shows the alarms for that controller only.
Error 'Object does not exist' when trying to use 'is like' with Device ID in a list view qualifier.
Example:
CyberStation
Documentation
When adding the qualifier DO NOT write the word ID after the device name in the value field, Continuum will automatically add it when the list view is saved.
NOTE: If getting the error even after removing 'id' from the qualifier try entering the full path to de device.
  • 16118
This is a heading
