Error: NS #291 lcaErrNsUnexpectedLink
  • Error: NS #291 lcaErrNsUnexpectedLink
  • Sacco
    Sacco
‎2018-09-06 02:22 PM
The link between the parent and the child record was unexpected.
LonMaker
NL220
Vista
LNS
This error usually indicates that the LNS database has been corrupted.
If you encounter this error, you should use the Validate method to run a database validation, and consider switching to a backup database.
  • 4165
