Error: NS #286 lcaErrNsLmobjNvNotDynamic
  • Error: NS #286 lcaErrNsLmobjNvNotDynamic
  • Sacco
    Sacco
‎2018-09-06 02:22 PM
The specified network variable is not dynamic.
LonMaker
NL220
Vista
LNS
This exception may be thrown if you attempt to assign a static network variable to a LonMarkObject with the AssignNetworkVariable method, unassign a static network variable from a LonMarkObject with the UnassignNetworkVariable method, or delete a static network variable with the Remove method.
You can determine if a network variable is dynamic or not by reading its IsDynamic property.
  • 4163
