Error: NS #285 lcaErrNsLmobjNotDynamic
  • Error: NS #285 lcaErrNsLmobjNotDynamic
  • Sacco
    Sacco
‎2018-09-06 02:22 PM
The specified LonMarkObject is not dynamic.
LonMaker
NL220
Vista
LNS
This exception may be thrown if you attempt to assign a network variable to a static LonMarkObject with the AssignNetworkVariable method, unassign a network variable from a static LonMarkObject with the UnassignNetworkVariable method, or delete a static LonMarkObject with the Remove method.
You can determine if a LonMarkObject is dynamic or not by reading its IsDynamic property.
  • 4162
