Error: NS #282 lcaErrNsNssEngineInitTimeout
  • Error: NS #282 lcaErrNsNssEngineInitTimeout
  • Sacco
    Sacco
‎2018-09-06 02:22 PM
The application timed out starting the LNS engine process (NssEng.Exe).
LonMaker
NL220
Vista
LNS
This could be an indication that LNS is not installed properly.
If you encounter this error, you should try the following steps in order.
  1. Restart the "Echelon LNS Server" service
  2. Rebooting the PC
  3. Re-installing LNS
  • 4161
