Error: NS #188 lcaErrNsSysimageUpgradeFailed
  • Error: NS #188 lcaErrNsSysimageUpgradeFailed
  • Sacco
    Sacco
‎2018-09-06 02:22 PM
New system image failed to upgrade.
LonMaker
NL220
Vista
LNS
This error will be generated when you invoke the LoadEx method on a device, and the new system image is successfully transferred to the device, but the switch from an old system image to a new system image fails.
 If you encounter this error, try invoking the LoadEx method again, or loading the previous system image back into the device.
  • 4160
