Error: NS #181 lcaErrNsInsufficientRtrsForMnc
  • Error: NS #181 lcaErrNsInsufficientRtrsForMnc
  • Sacco
    Sacco
‎2018-09-06 02:22 PM
No routers exist to complete logical path needed for monitoring and control.
LonMaker
NL220
Vista
LNS
When initially creating a multi-port router, the internal L-IP FT-1250 channel was designated as an existing FT-10 channel.  The drawing was built and then couldn’t be commissioned due to the physical topology not matching the drawing.
With no logical path for the controllers and you attempt to move them to another channel, you must first  correctly define the router in the Visio drawing.
  • 4156
