Error: LNS #151 lcaErrUniqueNameRequired
  • Error: LNS #151 lcaErrUniqueNameRequired
  • Sacco
    Sacco
‎2018-09-06 02:20 PM
You attempted to create an object with a name that is already being used by an object of that type.
LNS
NL220
LonMaker
Vista
For example, the name assigned to all LonMarkObject objects must be unique. Therefore, if you use the Add method to create a LonMarkObject and specify a name that is already being used by another LonMarkObject, this exception will be thrown
Name LonMarkObject as something unique.
  • 4213
