Error: LNS #15 lcaErrInvalidCollectionIndex "Invalid OLE collection index(Subsystem: LNS, #15)
  • Error: LNS #15 lcaErrInvalidCollectionIndex "Invalid OLE collection index(Subsystem: LNS, #15)
  • Sacco
    Sacco
‎2018-09-06 02:21 PM
A query to an LNS collection object has been made using an invalid index number. The range of valid indices starts with 1 and ends with the current item count.
LonMaker
NL220
Vista
LNS
When launching the plug-in of a device.
  1. In NL220, go to the "Plug-Ins" menu dropdown
  2. If the option exists, Verify that the option "Simple string command" is deactivated.
  3. If not, uncheck it and try to relaunch the plug-in.
*Note this option has been removed in more current versions of NL220, there may not be an option represented.
  • 4173
