Error: DS #17 lcaErrDsInitValidationError, error : "Failed to initialize data server (subsystem dataserver, #17)"
  • Error: DS #17 lcaErrDsInitValidationError, error : "Failed to initialize data server (subsystem dataserver, #17)"
  • Sacco
    Sacco
‎2018-09-06 02:20 PM
The Data Server failed to initialize properly.
LNS
NL220
Vista
This exception could be thrown if your application specifies an invalid name or index number when retrieving an object from the LNS database.
This error can occur when trying to monitor a variable with the DataServer of LNS 3.08.
It is a corrupted database error. The best thing to do is to come back to a previous backup of your database
  • 4218
