Error 1001 could not load file or assembly sorttbls.nlp
  • Error 1001 could not load file or assembly sorttbls.nlp
  • AbeMeran
    AbeMeran
‎2018-09-06 12:37 PM
Continuum application fails to start with error 1001 could not load file or assembly Sorttbls.nlp
CyberStation
.Net corruption.
Uninstall and re-install .net
May have to re-format the hard drive and re-install windows if problem is not fixed by the above.
  • 7432
