Equivalent / replacement for actuator MS61-7203 from the European portfolio
  • Equivalent / replacement for actuator MS61-7203 from the European portfolio
  • SESA150559
    SESA150559
‎2018-09-06 10:20 AM
Needs a European replacement for a US product.
MS61-7203
AV-822 linkage kit
TAC Forta
Replacing US portfolio product from EU equivalent.
Use the TAC forta actuator that suits the application best. Together with linkage kit AV-622 this will fit most of the valves where the MS61-7203 fits.
  • Field Devices
  • 13501
