Epi-Builder display of expiration date workaround
  • Epi-Builder display of expiration date workaround
  • sesa119747
    sesa119747
  • Carl_Slack
    Carl_Slack
‎2018-09-06 02:43 PM
Epi-Builder
The problem lies in the format of the expiration date in the Epi-Builder software.
Epi-Builder display of expiration date workaround.
Recently discovered was a minor issue with the display box of the expiration date field on print pre-view and while printing a card with this attribute. There are multiple formats to select from ie.. mm/dd/yyyy or mm/dd/yy hh:mm:ss etc... but even though you may have selected just to display the mm/dd/yy. What would be displayed is the format mm/dd/yy hh:mm:ss.
A simple workaround is to resize the box that houses the attribute when editing the badge layout to only show the desired mm/dd/yyyy.
  • 3213
