Enterprise Server Backup Failed - File is Corrupt
  • Enterprise Server Backup Failed - File is Corrupt
  • GavinHe
    GavinHe
Sisko GavinHe Sisko
‎2023-01-09 04:33 PM
on ‎2023-01-09 04:33 PM
When performing a backup of all Servers and All Data on an Enterprise Server the backup fails and generates an error in Software Administrator indicating the backup is corrupt although the backup is not corrupt.
  • EcoStruxure Building Operation Workstation
  • EcoStruxure Building Operation Enterprise Server
There is not enough free disk space on the Enterprise Server to save the backup file created.  The error generated in Software Administrator is a generic error.
Check the Trace Log for Internal Server Error: Insufficient_Space_For_Backup
If this is evident free up additional space on the Enterprise Server and re-try saving the backup.
  • GavinHeward23
