Engage App BLE Filtering
  • Engage App BLE Filtering
  • PeterEdvik
    PeterEdvik
  • Jonas_Brissman
    Jonas_Brissman
Janeway Jonas_Brissman Janeway
‎2020-06-04 04:59 AM
on ‎2020-06-04 04:59 AM
When "Engage App BLE Filtering" set to "True" in an RP-C it is not possible to connect to the RP-C via Bluetooth using eComission SmartX controller mobile application.
How do I set "Engage App BLE Filtering" to "False"?
Building Operation eCommissioning Tool
A factory reset of an RP-C will set "Engage App BLE Filtering" to "True".
The "Engage App BLE Filtering" is also set to "True" when upgrading the RP-C from firmware version 2 to version 3.
The only way to set "Engage App BLE Filtering" to "False" is to use the  eCommission SmartX Controllers mobile application connected to the RP-C using an IP connection.
  • JonasBrissman20
100% helpful (1/1)
