Enabling TAC Xenta controller service menu
  • Enabling TAC Xenta controller service menu
  • PeterEdvik
    PeterEdvik
  • MikaelKrantz
    MikaelKrantz
  • SESA116857
    SESA116857
‎2018-09-06 03:10 PM
Last Updated: Janeway PeterEdvik Janeway ‎2020-01-29 05:59 AM
Field Devices
  • TAC Xenta OP
  • TAC Menta
To enable the TAC Xenta controller service menu, which is accessible from the OP, this option must be selected when the OP tree is edited/generated.
Edit the OP tree in the OP configuration tool, and select Formats > Settings and "Use Service Menu" option will be available. When this option is selected the OP will be able to view the TAC Xenta device system program version, device name, and network address. In addition to that the OP will also be able to configure the I/O modules and restart the device.
  • Field Devices
Tags (5)
  • 1801
  • MikaelKrantz19
  • operator
  • panel
  • PeterEdvik20
